Monday, 05 January 2026
AN #165 - EEprom programmer (Part 2) Print
by Evert Dekker
(This AN has also Part1, follow this link )
What is it?
It’s an Eeprom programmer controlled by Bascom Avr and is capable of programming in circuit Eeprom’s up to 512Kb. Standard Intel Hex8 file is required.
Extended Linear Address Records for Eeprom’s bigger then 16bits addresses is not (yet) supported, but easy to implant.
I wrote it primary for my other application note RC2 sound / voice playback.
Required tools
For the PC side there’s an upload program that sends the Intel Hex file to the AVR.
Program is written in VB6-Sp6, source code is also available.
Note from MCS
I liked the idea of Evert very much and extended his application with an ASM-BIN converter so you do not need Studio to convert the files.
The code
Code is written and tested in Bascom 1.11.9.0.001 license.
' I2C Eeprom programmer
'Upload your Eeprom files through serial connection in the I2c Eeprom
' No extended address supported, so max 512K Eeprom
' By Evert Dekker 2008 i2cprogrammer@Evertdekker dotje com
' Created with Bascom-Avr: 1.11.9.0.100
$regfile = "m128def.DAT"
$crystal = 16000000
$baud = 19200
$hwstack = 70
$swstack = 70
$framesize = 60
$lib "I2C_TWI.LBX" 'Setting up i2c hardware bus
Config Twi = 400000  'Hardware i2c bus speed
Config Scl = Portd.0 'TWI (i2c) ports on the Mega128
Config Sda = Portd.1
Const Addressw = &B10100000 'slave write address eeprom
Const Addressr = &B10100001 'slave read address eeprom
Dim Startbyte As Byte , Instring As String * 45 , Complete As Bit
Dim Temp As Byte , Temps As String * 3
Dim Bytecount As Byte , Addresshigh As Byte , Addresslow As Byte , Recordtype As Byte , Databyte(16) As Byte , Checksm As Byte
Dim Lus As Byte , Pos As Byte , Checksum_calc As Byte , Checksum_error As Bit
Enable Urxc
Enable Interrupts
On Urxc Bytereceived_isr
'=== Main ===
If Complete = 1 Then  'Wait until the buffer is filled with one line
Gosub Process_buffer 'Process the buffer
Gosub Calculate_checksum 'Calculate the cheksum
If Recordtype = &H01 Then  'EOF finished, send a ACK and return
Print "Y";
Else
If Checksum_error = 0 Then 'If there's no error continue
Select Case Recordtype 'do something with the recordtype
Case &H00 'Data byte
Gosub Prog_eeprom 'Recordtype &H00 = databyte, so lets programm the Eeprom
Case &H02  'Extended Linear Address Records, not (yet) supported
nop
End Select
Print "Y"; 'Checksum ok, send a ACK
Else
Print "Z";  'Checksum error send a Nack
End If
End If
 Complete
= 0 : Instring = "" 'Reset the variable
End If
'=== Subroutines ===
Prog_eeprom
I2cstart 'start condition
I2cwbyte Addressw 'slave address
I2cwbyte Addresshigh 'Highaddress of EEPROM
I2cwbyte Addresslow 'Lowaddress of EEPROM
For Lus = 1 To Bytecount
   I2cwbyte Databyte(lus) 'value to write
Next Lus
I2cstop 'stop condition
Waitms 10 'wait for 10 milliseconds
Process_buffer
Temps
= Mid(instring , 1 , 2) : Bytecount = Hexval(temps) 'Read the numbers of bytes
Temps
= Mid(instring , 3 , 2) : Addresshigh = Hexval(temps) 'Read the high adress
Temps
= Mid(instring , 5 , 2) : Addresslow = Hexval(temps) 'Read the low adress
Temps
= Mid(instring , 7 , 2) : Recordtype = Hexval(temps) 'Read the recordtype
For Lus = 1 To Bytecount 'Process the number of data bytes
 Pos
= Lus * 2
 Pos
= Pos + 7
 Temps
= Mid(instring , Pos , 2) : Databyte(lus) = Hexval(temps) 'Read the databytes
Next Lus
Pos
= Pos + 2 'read the last byte
Temps
= Mid(instring , Pos , 2) : Checksm = Hexval(temps) 'Read checksum
Calculate_checksum
Temp
= 0 'Add up all the databytes
Temp
= Temp + Bytecount
Temp
= Temp + Addresshigh
Temp
= Temp + Addresslow
Temp
= Temp + Recordtype
 Temp
= Temp + Databyte(lus)
Next Lus
Checksum_calc
= 256 - Temp 'taking its two's complement
If Checksum_calc <> Checksm Then 'Compare it with the readed value
 Checksum_error
= 1
Else
 Checksum_error
= 0
End If
Bytereceived_isr
Temp
= Udr 'get the binary value that came across
If Temp = &H0D Then 'Received CR = end of line, line complete
If Len(instring) < 8 Then 'To short, startover again
 Complete
= 0
 Instring
Else
 Complete
= 1 'String is complete set the flag
End If
End If
If Startbyte = &H3A Then  'we have previously received the start byte and this is now data
If Temp > &H0F Then 'Add incoming data to buffer
 Instring
= Instring + Chr(temp)
If Len(instring) > 45 Then Instring = "" 'String is to long, reset and startover again
End If
End If
If Temp = &H3A Then 'if we received an : then its the beginning of an new line.
 Startbyte
= Temp
 Complete
= 0
 Instring
End If
